scienic 1.9 dti fuel pump
hi
i have got a renault scienic 1.9 dti 1998 model it has got a bosch pump i needed a new diesel pump for it i managed to get another one i put it on i timed it up plugged the fly lead in and the other plug for the stop solonoid are these pumps coded as it will not spill diesel i have tried it with the spring and plunger out of the solonoid still no joy there is diesel gettting to the solonoid as well
thanks steve
Hello and Welcome to the Forums Steve.
I'm sure someone will be able to assist with your post shortly.
Ottoman
Hi I am about to change mine as well after my engine blew up. I believe from what the breakers told me that the fuel pump is linked to the immobiliser, he told me to swap the pump on the replacement engine for my original. Hope this helps you, please let me know if you find out how to code it it would save me time on swapping the pumps.
