Hi everyone,
I've just brought a 2001 1.6 scenic cheap as it needs a new clutch. When driving it i noticed a very slight scraping sound coming from the drivers side of the engine, near the camshafts. if you remove the oil cap it does appear to get slightly louder indicating its comming from inside. Is there anything that is prone to failing in this area as even though i now have the clutch out i was just wondering if its worth continuing?
Also when i took out the clutch i found that it was almost brand new however the friction plate was contaminated with oil comming in from the rear of the engine. Does anyone know of anyone who either sells just the friction plate or reconditions old ones?
Bit long winded i know but thanks for reading.
