Just purchased Clio mkIV
Problem fiddling with new toy!
Pressed the release sd card button. Maps disappear.
Try to pull out the sd card - will not budge. Seems solid, no spring bounce back as on my laptop. Stucked!
Tried to push a little harder to get back in place - computer say no card inserted!
Try tweezers no luck as fat fingers cannot grip.
could anyone help please? Is this a common problem or am I special?
Captur 2017 1.5DCi EDC
Is it jammed, or is it that you just can't get hold of it. If the latter some sticky tape might help.
51 plate Laguna 2 1.6
The slot mechanism can become faulty. I had one but eventually the card released after many attempts, so I can't help with technique. If it's a micro card in an adaptor, and you do get it out, don't put it back in!
Transfer the data to a full-sized card and try that.
Different brands of SD card do vary ever so slightly. I'd only ever use Sandisk after a Transcend went bad (but the lifetime guarantee worked).
