Hi i am changing the front seat in my 2001 d55 kangoo before i do can someone advise of any thing i need to do i have to change the seat belt pre-tensioner can i just unbolt this and swap it?? or do need to take some precautionary measure?? before i start messing with it i dont have airbags fitted or anything if this makes any difference. thanks for your help
L
Only precaution is to disconnect the battery for 30mins prior to carrying out the work to make sure the detonators are dischaged.
thanks very much so its not going to go bang if i remove it and fit it to my other seat!! can i achive the same result just unplugging it with plug on top of it or am i better to do as you say with the battery? thanks again:d
