21 - 21 of 21 Posts
Not sure if your vehicle uses the same set up but I seem to remember that the 1.9dci Laguna that I had used a system where the crankcase vent went to the oil separator that was part of the oil filler tube, any vapour would go to the inlet pipework and excess oil would run back to the sump via a hose, this hose could clog up and if it did excessive oil consumption was the result, it never happened to my engine but I remember reading a few post on the subject.
So if you haven't already check that any hoses that connect to the oil filler tube are clean and clear.
Cheers, TTT
21 - 21 of 21 Posts
