1 - 9 of 9 Posts
I have 1.9 dci st and when i put the foot down to overtake there is dark ish smoke from exhaust is this norm its on a 52 plate with 47k on it .
it still has the power
regards james
I'd be worried, if there was black smoke present all the time, rather than when under load. And I'm presuming that the engine isn't using oil?
You might want to try using a Diesel fuel additive (I've tried Miller Oils) and give the car a good run (extending it through the gears a bit - when its warmed up & where legal of course;) ). This should help clear things out as far as is possible, and possibly give a bit more power & mpg as well.
Hope that helps.
Paul:)
Well, kind of - what's called an "Italian tune-up", is to take a car which is normally driven very gently and/or in town out on an extended run whereby it is driven very hard through the gears. Using a fuel system/injector additive would make this type of flushing of the engine a bit more effective (and probably better for it in the longer term too).
Paul:)
1 - 9 of 9 Posts
