1 - 10 of 10 Posts
Hi guys ive fitted aftermarket speakers and cut the plugs off so i can fit spades, however the original wiring is the same colour for both + and - and ive now forgot which is which, how can i figure it out??
Andy
Stunning advice mate i'll use a multimeter one end at the ISO the other at the door to trace which wire is which
Hi it tends to be the biggest spad connector on the speaker that is + and the smaller one being - i hope this helps all the best Donald
Some times they can be the same size so might not help all the best.
RIP 31-12-2008
The speakers should be phased correctly, if you place your fingers lightly on the speaker cone and turn on the radio/cd unit the cone should move foreward, if both speakers do this then the phasing is correct and the wiring is the right way round, if the cones move slightly backwards then the wiring is the wrong way round.
Regards Leroy
1 - 10 of 10 Posts
