Having Trouble, has anyone had this problem, 03 espace mk4 2.0t speedo started cutinng in and out and abs light coming on, now speedo not working aabs and other warning lights on, have had abs pump changed, just the same, had to auto electrian checked and cleared faults worked for 15mins then the same again! had it in renault main dealer and they say that its electrical!! :eek: don't want them to start dismantling as it will cost big bucks, said it could be ecu behind dash or under seat but not sure:confused: has anyone had similar prob or now reliable person to mend in blackpool/northwest help!!
not sue about the espace but some clio have the speed sensor that works of the abs ring and as you say both speedo and abs are not working it could be something as simple as an cracked or missing abs ring worth a look could save you a lot of money.
I was just about to say the same.
Its no coincidence that the 2 failures have occured.
Paul
car now in 4th garage guyguy thinks its dash we shall see:confused:
