Now weve just had a spell of warm weather my passenger window has started squeaking when going down. Ive sprayed the rubbers with some silicon spray which has helped a little but its bad when its been in the hot sun any tips????:d
Hi it should not really be doing this i would take the door panel off and see if all is well with what the window runs on going up and down to see if all is well and tight on the window runners i hope this helps all the best Donald
Mine does aswell,Been like that in the very small space I have owned the car,I will get the panel off asap and let you know a fix!
Yes its worth i try my sister got here new scenic two weeks ago and had to take it back because it had a sticky window they greased it up and hay presto
window
thanks will have a look as soon as i have a weekend spare, mine only does it when its really warm??
