Hello all.
The Starter Motor.. What a joy it has been to try and source one of these little devices.
First question: After calling / emailing more companies than I have done in the last year.. can anyone tell me is there a definitive part number for a starter motor? I was told by a Renault Dealer that the engine in the Clio is a E7F-708. Only 1 parts supplier out of.. lots.. claimed to have the correct motor after supplying them with the reg and engine type.
Second question: I have read the articles listed on the forum and yes I will check the connections and such if I can find them. I am assuming the starter is located on the front of the engine (nearest the rad) as far as I can see below the battery. If it does need to be changed how is it removed? I can only see two bolts from underneath (assuming I have the right part to begin with) is this all it is held in place with?
Any help would be greatly appreciated but please bear one thing in mind. The car is 40 miles away stranded on a friends driveway (fortunately a good friend) so I cannot nip out to pop the bonnet for a shufty.
Cheers to all.
Paul
Paul
