hi all,
i have a 1.6 16valve classic alize megane v-plate
i have been having problems with trying to start the car at random intervals( keeps turning but no ignition)
after having the rac out they told me to replace the tdc sensor and have a look at the immobiliser?
also there is a tapping noise under acceleration and a distinct lack of go... i have had the manifold replaced due to having a crack in it.
any ideas or shared experiances would be grand!!!
I too have a similar starting problem but have found that if i bump start the car it tends to start first time so would suspect that it is not the immobileisor
