1 - 8 of 8 Posts
Occasionally around parking there'll be a screech from the steering column or the steering system somewhere when turning the wheel. Is this a known problem and if so what does it lead to?
No warning lights or problems steering otherwise ...
Cheers!
Hi Powell - have you checked the condition of the auxillary drive belt and all its pulleys - are you losing any fluid from th epower steering resorvoir.:)
It should be in the manual as it will be a routine check with belt adjustment.
Usually the belt has becone 'shiny' and hence cannot grip properly.
I referred to spray on 'belt slip' the can, I have, is called 'belt dressing' spray it on as the engine ticks over if you have sufficient access to the belt. Quite dramatic quietening of the squeal.
hi Powell - get it sorted soon because if the auxilliary belt breaks it can cause damage to the timing belt and you could end up with a wrecked engine.:)
1 - 8 of 8 Posts
