The rack and/or pipery on the Megane has sprung a leak
It's hard to see exactly where the leak is, but fluid is dripping from the bottom of the pinion housing - though I can't tell if it's coming from a loose union or the pinion seal. Access is a bit tight in there....
Is rack removal one of those things to leave to a garage, or can it be DIY-ed? Working on it five feet in the air on a four-post ramp might be a bit more convenient than on my back....
Also, it seems that either TRW or SMI racks were fitted to this vehicle - mine has a TRW. Can either rack be fitted as a replacement, or are the pipe connections different?
Cheers,
David
Cheers,
David
