Hi guys
I have a phase 1 lag 2 V6 2001 with a very tatty steering wheel.
Would a steering wheel from a phase 2 2006 GT fit?
AFAIK All Renaults have the same design of Column. For Instance Clio, Lag & Scenic fit a Trafic But you WILL need to do some practical research. First strip yours, by removing but not disconnecting Airbag. Take photos, especially how many connectors on your airbag.
Then off to Scrappy to compare. Also check if your airbag will fit the newer wheel, if they are different connections. HTH.
Battery Should be Disconnected when playing with Airbags
I've already played about at the scrappies, Megane wheels do not fit the Laguna steering column. The boss is the right diameter, but it does not slide down far enough. Didn't even bother trying clip wheels.
Was hoping someone would confirm whether lag 2 phase 1 and 2 wheels are interchangeable as there wasn't any kicking about I could try.
