I have a set of refurbished 19" BBS wheels without any tyre. I plan to fit the on my car within the next 4 or 5 months. Unfortunately I don't have any space to store them other than the garden. I was thinking to put them in bin bags and lay them horizontally. Is it safe to keep it like this through winter? Even though moisture will be present.
If by refurbished you mean blasted and re-painted or lacquered, probably come to no harm.
At least not if the paint/lacquer is a decent job.
If you really want to be sure, a coat of oil or grease and wash off before use.
And better under a tarp then bin bags...less condensation.
No place to get them under cover?
I'd give them a spray with something - maybe ACF50 or a similar motorcycle anti-corrosion spray.
Some are quite expensive, but I've used Putoline PPF52 on the engine casings of my bikes for a few years and have some Muc-Off Motorcycle Protectant too - both cost about a tenner for a can which should do all 4 wheels.....
Liquid Bottle Drinkware Alcoholic beverage Gesture
Used to use Fenwicks over wintering product on the caravan and it always seemed to do a really good job. It washed off easily enough after too, but not a mark on the caravan despite it sitting on the drive all winter.
Not expensive either, less than £15 for enough for a couple of winters on a large twin axle van and it’s four alloy wheels.
Just thinking - if they are going to be in the garden, even wrapped in plastic or in a tarpauline, maybe put some layers of cardboard down underneath as a bit of insulation from the cold/damp ground.....
Probably better with a couple of 2x2s to lift them off the ground?
