Hi. My laguna phase 2 has just developed a whining sound. It only happens when cruising at around 70 or 80.
There is no change in performance nor do I have problems changing gear and the clutch is absolutely fine. It's just 6 gear that makes the sound only.
PK6 gearboxes do suffer from premature bearing wear. The actual fix is quite easy once the box is out, but getting it out is a bit of a struggle. Its best to do the box asap before it implodes
Totally agree, Having just changed a PF6 at 161,000 For just that reason.
