How do I remove the plastic cover from the engine (2005 1.2 Clio 2)
K knaph02 · Registered Joined Mar 27, 2011 · 1 Posts Discussion Starter • #1 • Mar 28, 2011 How do I remove the plastic cover from the engine (2005 1.2 Clio 2)
Ralph · Technical Supremo, Platinum Member Joined May 16, 2008 · 7,926 Posts #2 • Mar 28, 2011 If its like the Diesel they just pull off, it's on 3 rubber mounts that are just a tight push fit, if you get your fingers under the cover at the cam belt end you can sort of leaver it up.
