i tried all the suppiers i used to use before i had to leave work none of them could get one ended up having to go to the dealer to get one cost somewhere between £20 & £25 for the gasket
(thats if its the almost triangular shapped sump with the rubber gasket)
Ok next Q ...... does anybody which gasket i need?
apparantly there are 3 choices for my model ..... fibre .......... steel ............. or summit else.
Anybody?
1996 espace RT alize 2.1 TD
hi again i have the 1994 Alize and just today infact helpped a friend with his 1996 Alize, so i stuck my head under his car to have a look at the sump and its the same as mine, which when i replaced it it was the rubber gasket check back tommorow i have a spare sump in the shead ill take a picture of it and post it here then u will know for sure.
