Can anyone tell me what size is the Sump Nut Washer on my 1.9dci F9Q before i take it off to find out and then have to walk 4 miles to get one.
Thanks in advance :d
To whom it may concern-
My engine is 1.9dCi 120bhp F9Q code (2005).
Sump nut is an M16 x 1.5mm pitch magnetic plug with an 8mm square drive. The correct washer is a 16mm crushable copper washer which needs to be replaced each oil change (otherwise for a proper seal you run the risk of over-tightening and therefore damaging the sump). There is no torque set because torques are stipulated by engineers to ensure correct "stretch" of a bolt holding two components together :d.
According to Renault service manual MR395 dated Feb 2009 torque for the sump nut is 20Nm for all F9Q engines.
:toast:
remember Murphy never sleeps
just bought a genuine Renault oil filter and it comes with sump washer, its plastic with a crushable lip,also its fifty mm in length shorter than after makers sixty five cheers
