Has anyone experienced the alarm going off every 5 mins?
on Sunday it kept going off for no reason, i just wondered if the heat had effected it some way?
only did it in the day time.
Although later in the evening i wet the bonnet to wash some bird poo away and it went off again!:steam: it must be very sensitive.
After reading prevous posts on this i am wondering if the bonnet sensor is the cause?
Any ideas?
Funny you should mention that!
On the Megane cc the alarm has been going off every so often - with the roof open. I though it was because I hadn't switched the sensors off correctly. Although I was sure I had.
Apparently the alarm went off again on Saturday - with the car on the drive & the roof up!
This makes me think either that one of the door sensor switched must be faulty - like you reading other threads I am thinking it is the bonnet at fault.
Car is due its first service in a few months so will mention it to dealer then!
