I`m trying to remove the sunroof from a J reg espace so i can put it in my car.
I have removed the 5 T8 torx that hold the blinds on and I have removed the glass & part of the handle.
How do I remove the rest of the frame ? I cant see anymore bolts or whats holding it there :(
does your car have a busted one or are you fitting it as an after market fit.a mate of mine had an espace without s/roof he wanted to fit one and was told the frame work for the factory fitted sun roof was fitted before the main roof don t know for shure good luck
thx for the reply :)
Managed to find out how it was held in, under the roof carpet foam stuff was about 12 rivets that I had to drill out.
Mine is not broken, it just doesn`t have one and the front roof carpet is missing So I`m using the carpet and sunroof from the spare espace to repair mine.
