Have seen that this is a common prob, but cant find any real answer to the prob.
Ive had the carpet and soundproofing out and managed to get 99.9% of the water out and had a good look around but cant see where its coming in.
I did however notice that there might be an outer trim missing.
Can anyone tell me if there should be 1....
Thanks in advance
firstly have you checked that all the drains are not blocked,also if you remove the plastic grill below the wipers and check the drain holes either side of the bulhead.
hope this helps good luck.
