Where will I find my Top Dead Centre / Crankshaft Position Sensor? Based on information online, the general location is the lower right side of the engine, below the cooling thermostat housing.
However, I just can't seem to locate it on my vehicle. I've attached a few images.
Thank you.
Megane III 1.6 Petrol Hatch 2009 (BZ0H)
On the Clio III 1.4 16V, I removed all the battery & tray looking, as you say the usual place is under the thermostat housing.
Turned out it was on the back of the gearbox bell housing, only real access was under the car/engine looking up, was clearly visible then :)
Hope that helps with your Megane III
