If the TDC Sensor on a Megane1 1.4 16v is failing/failed what symptons would be most obvious?
Starting problem?
Uneven engine tick-over?
Lack of power?
Anything else?
Starting problem?
Lack of power?
Anything else?
Hi, Dont quote me on this, but i had problems with my laguna 2 , 3.0L V6. Started fine, drove it for a while then it just died on me. I got a friend (Renault Mechanic) to do a diagnostic test and he found that one of the TDC sensors was not working, The engine management system seems to stop any power going to the spark plugs, if this fault occurs.
If you need a new sensor try revs online leeds or flea bay, but make sure its a TDC or camshaft sensor not a crankshaft sensor.
