Im having problems starting my scenic 1.6 rxe. I have located the tdc sensor and have take the 2 bolts out but am unable to remove it from its location. Can anyone advise me on how to remove it? I removed the bolts for the cable tract that runs about the tdc sensor but that didnt help.
Any help would be grateful
Don't worry, I successfully found it and cleaned all the crap off it!
OK so the black plastic cable track above it needs it's bolts removed and pulled outwards. It's puts up a bit of resistance but you just need to really tug it outwards. Then push the TDC sensor up into the gap behind the cable track and out. It's MUCH easier to get out than it is to get back in. I removed both the air box and the battery to gain proper access but it's still a REALLY tight fiddly job. It's horrible... I dread the next time it needs done.
If you need any more help let me know. And when those suicidal thoughts come just think happy things :d
