Need some tips on setting up the TPS on a 2.0 1994 espace.
Does the throttle butterfly need to be completely closed before adjusting the TPS. I know the adjustment is to be able to hear a click from the switch just as the throttle is pressed, but i am not sure if the butterfly should be slightly open or fully closed before TPS adjustment.
All the TPS's I've fitted previously have been set when the throttle is completely closed,so I suspect that your Espace would be the same.:)
Why are you replacing/adjusting it?.Have you got problems?.
