Ok. With most things mechanical I'm fairly ok but this one has got me head scratching. My indicators have lost their tick. My headlights left on buzzer has also stopped working so its safe to say that they are probably connected. they were working and my indicators and headlights work as they should so I suspect a loose connection to what ever makes the noise. My questions are these:
Where is the unit that makes the noise - can't find a reference to it in Haynes.
What fuse controls it?
Lee:confused:
im not sure they are connected, as my headlight warning sound works, the right indicator ticks, but the left doesn't.
The sounds sporadically come back again and then go (Together). If I could just find where the unit is then I could have a go at sorting it....
Is that a small speaker built into the unit or part of the unit that needs to be replaced as a whole?
