Does anyone know which tightening torque it should be on connecting rod bearing and big end bearings? Should also need one on the oil pump bolts if there is. For my engine Renault Espace 2.0T -04 F4R-794
I'm not sure, the figures look OK but on one of the forums it talked about stretch bolts being used for the big ends with angle tightening needed so I'd be cautious especially with the title including the word 'generic'.
Main bearings Renew bolts/nuts
Main bearings Stage 1 20 Nm
Main bearings Stage 2 62°±4°
Big end bearings Renew bolts/nuts
Big end bearings Stage 1 25 Nm
Big end bearings Stage 2 110°±6°
Oil pump to cylinder block 24 Nm
Sump bolts stage 1= 5 Nm stage 2 = 14 nm
