1 - 9 of 9 Posts
Any advice on this issue would be welcome.
Looking in the engine bay the other day (2004 2.2 dCi - Espace) I noticed a chunk missing from the rim one of the plastic timing belt wheels (may be a tensioner) it is about the size of a penny, but semi circular in shape. It only just comes in contact with the belt . I will try and get a photo.
The question is should I leave it and keep an eye on it or have it replaced.
Hi ns.thomson
If any of the pulleys shatter it can cause an expensive repair such as
bent valves,damamged cylinder head,cracked pistons.
My advice is get it replaced at the same time replace the timing belt.
Sounds like you spotted some damage before it got too serious.
Are you sure your not talking about the auxillary belt which drives the power steering,aircon etc?.You would have to remove a plastic cover to see the timing belt.
I would replace the damaged pulley and the belt,anyway.:)
Lagti,
You are right - it is the auxillary belt and pulley - thanks for that. I guess failure is a lot less serious, but as you suggest worth replacing anyway.
It is a job I might attempt as I am assuming the setting of the belt relative to the pulleys is not critical as it is compared to a timing belt.
However access to the pulley is very tight - it appears to have a single bolt that hods it in place.
Feel a bit dumb now suggesting it was the timing belt - must have been due to reading the threads on the subject and subsequently looking for the worst.
N Thomson
Glenda,
Absolutely spot on with your advice, but I had inadvertantly mislead you - it was the auxillary drive not the timing belt.
NT
It's not a problem,we're all here to help.:)
There are no timing issues when changing the auxillary,but it's worth drawing a diagram of the way the belt feeds round the pulleys before you take it off.I have removed belts thinking that I can remember which way they go,only to try and put them back on and find that my short term memory isn't what it used to be!:rolleyes:
The belt is tensioned by a spring loaded unit and is under quite a bit of tension.Take care when moving the tensioner as if the spanner on it slips and the tensioner springs back and catches your hand,it hurts like f###!.Been there,done that!
The belt is tensioned by a spring loaded unit and is under quite a bit of tension.Take care when moving the tensioner as if the spanner on it slips and the tensioner springs back and catches your hand,it hurts like f###!.Been there,done that!.:)
OH yes...did that Saturday,thanks for the belated warning Lag:rolleyes:
Chickened out I'm afraid - got it done at a dealer while it was in for something else aprox £150 for new belt and tensioner kit including fitting.
Glad to hear you got it sorted,thanks for the update.:)
1 - 9 of 9 Posts
