bought a clio 1.4rt auto off e-bay with the torque converter knackered, it is in the process of being replaced, as is the gearbox shaft seal and I just wondered is there any more recommended things to do, or replace while the gearbox is out of the car. Thank you kind people in advance
That really is all there is to it really.As long as your sure that the gearbox is OK,I'd leave it at that.Are you using a new or second hand torque converter?
have a look in the oil cooler there may be bets of conveter in it if so there will be bits it places you dont need and may cost big money
Sorry,just thought of something....
I'd be tempted to take the sump off of the bottom of the gearbox and make sure it's all clean in there.Replace the gasket around it as I have known them to leak in the past.:)
Thanks, fingers crossed that the gearbox is ok, second hand converter bought from just renaults in Walsall. Only just passed my test 4 days ago and still haven't been out!!!
