Hi, need a little help finding out what the torque setting should be on the near side drive shaft of a Clio mk2 1.2 16valve. just had the abs ring changed and the torque setting was not used resulting in a split drive shaft, need the torque setting to avoid this happening again if anyone can help.
thanks
thanks
