right then here is my list.. ready...
cylinder head bolt torque settings.
rocker cover torque settings.
2003 megane 1.6I 16V K4M engine...
help help help;..please..
slipped belt, bendy valves...oh poo..
thanks in advance.. mark:crazy:
remember Murphy never sleeps
Hi 20 nm stage 1, angle tighten a further 240deg+-6. Engine cover is bit more complicated stage 1 bolts 22,23,20,13.8nm stage 2 bolts 1to12,14to 19,21to 24,15nm.stage 3 bolts 22,23,20,13 slacken fully.stage 4 bolts 22,23,20,13 .15 nm.sounds daft but from the manual.cheers
:crazy:got the head bolts part, but not the cover bolts?
are these bolt numbers??
:eek::eek:
Hi as said read from the manual show's the sequence of bolt numbers starting in the middle of inner bolts ,that's a lot of bolts best of luck lol
Err. Dont suppose you could do a drawing or even a scan....:crazy:
Please?
Pretty please?
Go on
