Hi, does anybody know if it is possible to torque the head down on a 98 1.6 Megane without using a special tool for angle tightening? For example, in the manual it tells you to torque all the bolts down to 20 lbs, then angle tighten them all by 100 degrees, surely this is just a way of increasing the torque using a different method? The problem is I don't know how to work out the basic poundage plus the given degrees to give me the overall poundage. Can anybody tell me how to do it using just torque settings, I don't even know the final torque settings for the bolts as the manual says tighten bolts to 15 lbs and then angle tighten to 110 degrees. Any help would be very very much appreciated, thanks, Paul
