Hi, before I ask yet another question i would like to say a big thank you for the all the help and advice I have received from forum members up to now.Thank you all.Just a simple query I need to buy some touch up paint how do I find out the correct colour?
MegP
Hi - to get an exact match you'll need the paint code which is on a label attached to one of the door pillars or under the bonnet. If in doubt write all the numbers down and when you go to buy a touch-up you'll see which matches.:)
RIP 31-12-2008
Hi there MegP, you should have a sticker either on the lower half of the drivers door pillar or under the bonnet that looks like the one in the pic. The paint code is in the oval part of the sticker and is normally the first set of letters/numbers on the third line down. However if you cant find the sticker if you give your reg number to a Renault dealer the paint code for your car should be on the database.
Regards Leroy
