yeh thanks mate i routed mine through the rubber flaps just below lights,then ran 2 feeds back down same side 2 wire indicators and tail lights on other side up through them TIGHT flaps lol.. tested wit multimeter worked perfect..thanks to all who helped with this...... all i nedd niw is a set of hydralic boot arms and window armsDid mine last Saturday, and did a thorough job taking my time in the process, and from start to finish, wiring the towbar plug as well, took about 3 hours.
Used a multimeter to find out which wires were to be matched in the plug, and did them one at a time.
The hardest part was routing the wire through the bodywork without drilling, but if you have a look here, there is some pics by Recycled Scenic.
http://www.renaultforums.co.uk/showthread.php?t=111095
