hi all,
My name is gemma, i bought a renault clio 1.2 16v in august 2006 and for about a month when the car is sitting idle the rev counter fluctuates and the car juders. Then about to weeks ago it started to take more effort to take off and when drining began to pull back. Now today the toxic fume monitoring warning light came on and stays on permanently. has anyone else had similar problems and if so can you tell me what you did to fix it.
Thanks Gemma:confused:
coil pack
Welcome to the forum, Gemma.
It could be a faulty coil pack, this will lead to a misfire and unburnt fuel entering, and potentially damaging, the Cat.
There are a couple of posts in the Clio FAQ about this that may be useful to you.
Thanks for your response Chris i shall check that out :)
