hi ya...HELP!!!
my renault traffic van has got a problem!!
when you come to change gear the revs stay up a bit longer than they used too and then after youve changed gear there is a flat spot till the turbo kicks in and its the same through all the gears
also when you put the steering on full lock and the van is moving it will some times cut out
now for the first problem i have had the throttle thing changed ( black box at the back of the peddal)....and the egr valve cleaned and checked, but its still the same
please can any one help ??
