Hi All,
Its been a while since I last posted and things have been going pretty well with "Fez" our 98 Trafic. He just went through MOT with small weld and I re did the rear brake lines and pistons but that was it.
One thing I can't find reference to is ignition timing? I have a timing gun and have previously carried it out on mk1 and 2 golf's but can't find any obvious timing port or marks that suggest fine tuning of timing? Any advise on this would be much appreciated.
Cheers, Chris.
Your engine got a distributor,
No distributor then timing set by the ecu, using TDC reference point on crank to adjust.
It has a distributor not ECU. So, TDC reference point on crank to adjust with strobe with light clipped to ht lead of piston number 1?
