1 - 11 of 11 Posts
Having problems with my van for 2 weeks now.
It ticks over but wont start.
Have changed fuel filter, cam sensor and was going to try the crank sensor though i cant find it anywhere.
Have looked online and people say its at the front of the gear box , have removed the undertray and been under the van and still cant see anything.
Can anyone help with this :confused:
Hopefully it is the crank sensor as i really need the van for work on monnday
Crankshaft speed/position sensor
1.9 engine is front of transmission bellhousing
2.0 engine is rear of engine cylinder block at flywheel end.
:d
:d
its the 1995cc engine , everywhere i looked online only said its at the bell housing so thanks for that :d
Hopefully the crank sensor sorts the problem out
Under the van and can't seem to find it anywhere,
It's at the passenger side at the cylinder block ?
Found out was covered in black tape so couldn't see it
Got the bolt out but now it won't budge
Feels like it's melted on
Any suggestions anyone to getting this off ?
Disconnected wire , removed the 8mm bolt but it won't budge
Tried penetrating oil to try and loosen any corrosion but with no luck :(
Not my day today ! Been out since 10 this morning trying to get it off
Discussion Starter #10
Still cant budge the sensor off , stuck on and the position of it theres no way to wedge it out with a flat head screwdriver. Been let down by a few mechanics to come out to the house.
Anyone any ides of how to remove the sensor if its stuck on ?
Looks like ill have to tow it to a garage
:d
Hi I have a vivaro and am struggling to find the crank sensor its 2007 2.0litre there is one plug at the back of the bell housing quite high up with silver foil wrapped around it but very hard to get to lying on you’re back , am I looking in the right place
1 - 11 of 11 Posts
