We had done brake work and service om this Trafic from 2008.
When we collected it (the owner is disabled) hubby drove. When this problem appeared, he told me he had problem getting the gearbox into Auto. Out of Neutral.
When we moved it on our yard once, there was no problem. We had the engine running on idle for the oil change.
After a about one week, we were ready to start the car and the battery was completely dead. So we canged battery and tried to start.
The gearbox wont go inte Neutral.
The shifting looks like this: when I release the lever (it goes into middle) - the gears shifts UP. Its like the neutral position of the lever, has moved downwords. I can shift gears down by never letting the lever go into the middle.
Nothing happens when lever is moved to left or right. Once I managed to get it into Reverse. But only once.
There are no faul codes on this matter. I have had DF078 -01DEF (pressure too low), but have found this:
"Improper use of lever when the vehicle is stationary may
lead to this fault."
"Check PR018 Hydraulic pressure, using the diagnostic tool, to make sure that the pump starts at 40 bar
and stops at 50 bar."
The pressure stays between 40-50 - I have CanClip.
I can here the pressure pump when I shift gears.
I can here the micro switches when I move the lever. Nothing to the left and right though.
An other thing - I have no connection with instrument cluster with canclip.Thegera shifting shows on the info display.
I can change into Neutral with canclip - but shift is only in the instrument cluster - not in the gearbox, the engine wont start.
So my question is: have any one seen this before?
Am I correct? Or can it be something else?
Thank you
Thank you
