Hi all,
My dads 2015 trafic done something really strange yesterday. Engine running. Pressed passenger window switch and engine cut out. Twice in a row.
Sounds like water ingress somewhere. Scuttle drains seem clear.
Where else is common for water ingress or have you any idea what the problem might be?
Thanks,
Rick
Sent from my iPhone using Tapatalk
Check drivers door loom could have a broken wire in this, assuming you used the switch from drivers side
If it was passenger side you pressed the switch then check passenger side door loom, before drivers side
  • Like
Reactions: rik220
Discussion Starter · #3 ·
Yea it was the switch on the drivers side. I would have thought a short here would blow the fuse? Creating an instance where the engine turns off seems rather strange. Unless a short affects the UCH.
Could be switching power off to ignition, ( Guessing here but sounds logical ) all down to immo system being controlled through right hand door system,,
  • Like
Reactions: rik220
