Hi all
I have a 2014 Trafic 2.0 diesel
New to this site so hope I get this right.
2 weeks ago reversed it into our carport, came out on Monday to start it and it just turns over( sweetly but doesn’t fire. Had a software plugged up through odd and it can’t find anything, plugged up a handheld reader( autel) and it says linking error, have disconnected battery for a day to try and reboot and that didn’t work,any suggestions would be gratefully received
Phil
Pump primer bulb while someone else turns the key.
Try easystart.
Is the battery fully charged, low voltage can crank but not give enough for the electronics
The battery spins over really fast but no signs of firing, will easystart make a difference even though it doesn’t fire.
Depends what the issue it.
Easy start will fire it as long as there is compression.
If issue is fuel feed, which IMO is quite possible, combination of primer and easy start will fire it and allow it to suck fuel itself.
If an electrical issue, different matter.
But gotta start somewhere.
Does it sound normal...whrrr whrrr whrrr?
Or just one whrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr ?
