Morning all.
Let me see if I get this right. Starting from the intercooler. The black pipe runs from the passenger side of the intercooler has a sensor on it, then runs to the throttle body. This then runs through the head, to the turnip. The large metal pipe runs from the turbo with heat back to the intercooler.
With me so far. Should the black pipe carry oil? Should the throttle body have oil? Should the fabric covered flexi pipe at the end of the metal pipe be covered in oil? There is a breather pipe running from the oil filler cap to the air feed pipe engine side of the maf sensor. Loads of oil around this. Although it could be from higher up. The turnip is very nice and shinny and so is the metal pipe.
Are there any gaskets that may need replacing. There's no excessive smoke under load. Our mk3 mondeo responce car kicks out more than mine.
Any ideas?
Any ideas?
