just had mine done today,can only be done at renault dealer,but as many times need be.mine must have been working at some point but when out of sync or something,somehow.
nigel
hi, does anybody know if you can reprogram used wheel sensors or can you only program them once
You can reprogam them - in fact you do not re-program the valve but inform the UCH control module what the valve code is. So reprogramming just writes the code to theUCH memory
Yes you can reprogram used sensors. In fact the sensors are not programmed, but the UCH control module is programmed with the code of the valve. So as long as the valve is OK there should be no problem
