I have an 02 Megane 1.4 Expression petrol version and have been looking on Ebay for some new wheel trims. What size wheel trims do I order. Are they 15 inch? They are the factory fitted trims but are a bit scuffed as you can imagine.
Hi steamer ... do a search on the forums, there is plenty of info and links available on how to size/re-size wheels, tyres and offset etc.
hope it helps:)
Hi there, if you want to know what size of wheel trim you need for the wheels on your car - look at your tyre size (on the sidewall), it will say something like 195/60 R15. The (195/60 R) relates to the tyre size and that its of a radial construction - the (15) states that its for a 15 inch wheel (diameter), its that part you need to go by.
Hope that helps.
Paul:)
