Hi there noticed that the new Renaults are now coming with the flatblade wipers as standard.
Ive got access to an almost new wrote off Laguna, is it a simple case of removing the blades and fitting them to mine, or will i need the arms?
How do the flatblades come off?
Andy
Hi there Andy.
I'm a bit unsure whether the arm can be converted from one type to the other, but if you have access to the wiper arms - I would swap them over as a complete unit, it'll save any potential problem.
Hope that helps.
Paul:)
You have two choices.
1. keep your existing arms and buy the flat blade wiper conversion blades for approx £30 and fit as normal.
2. take the arms complete, from the face lifted Lag & fit them to your lag!
The wiper blades themselves fromt the facelifted lag will not fit your arms!
Option 1 is by far the easiest, but option 2 may be cheaper,depends how much you will have to pay for the bitsd from the other Lag!
