hi guys i have a little problem with my car, ill try describe the problem in such a way i dont confuse people lol,
ok firstly i have a renault laguna 1.8 RT sport 1997.
yesterday i was driving home and noticed the temp gauge way higher than normal, pulled in and switched engine off, started back up and same happened, phoned AA.
They came up with the conclusion that it was either a sticky thermostat or water pump, while i was standing there with the AA guy it never overheated
thats mainley why he thought sticky thermostat.
Today i replaced thermostat and everything seemed ok until the temp started creeping up again then went to the top end of the scale. sometimes it will balance at the 3/4 mark which is normal and other times it will shoot right up to the max mark almost,
also noticed when the temp is balanced at 3/4 mark, when i turn on the heating in the car it will quickly put the engine temp up, why would this be?
as i stand the thermostat has been replaced, im now thinkin either water pump or head gasket?
im stuck now and need it sorting quickly as my mrs is pregnant and need the car.
sorry for the massive rant and i hope some1 can help me out.
