Discussion Starter #1 (Edited by Moderator)
Hi all
I was traveling down the motorway the other day at around 70mph, had to slow down briefly due to car being in front and then went to overtake and the engine cut out and the engine stop light came on. Rolled to the side of the road, the car failed to start. A quick list of things ive looked at so far are: cam belt which is fine, fuel filter is ok, all injectors are all getting fuel and if i start the car with my foot on the clutch, it tikes over but the minute i take my foot off the clutch it stops. The car will not start, theres plenty of battery life and it has water and oil. Any ideas would be much appreciated.
Many thanks
Jack
P.S. Really need the car to work pronto as wife due to go into labour anyday now!!!!
Scenic mk1ph2, RX4, ID35s11
details please....
what model is it, manual/auto gearbox
Favourite first check would be the tdc, before you get on to the more expensive possibilities:)
Do you not need your foot on the clutch or brake for a normal start?
