Hi All,
New user, long time laguna owner.
I have a 53 plate sport tourer, owned from new. I've always been happy with the vehicle and never really had any problems with it.
I have one now. My daughter has somehow damaged the passenger air event. Basically it will turn left/right but not up or down. Looking at the vent the clip that handles the up and down has come loose and needs to be clipped into the direction panels.
I've had a quick look at the vent and it appears I need to remove the fascia as this will give me access to the direction panels. However I can't see an easy way to remove it. I have unclipped it at the top and bottom but I can't prise it away on the other edges. reading on the forums it seems I will have to remove the entire column to gain access to remove the fascia? i can't believe this would be the case and be such a bad design.
Is there an easy way of removing the fascia? Pictures would be handy for where the clips are so I know where to applu the relevant pressure.
Barry.
Barry.
