Had the medianav replaced recently, but when i'm on the bluetooth either playing music or on the phone - there is 1 loud beep every so often - when you on the phone and the volume is full so you can hear the other person talking - the beep is so loud it actually hurts your ears.....
This is rather irritating - its to do with the bluetooth - why is it beeping like that?
and no its not the satnav warning me of my speed.
I believe its just one of those quirks which you get when owning something french :lol:
We've had reports of beeping and messages when phone battery is low... dunno if it is that.
If not, as you say you have had medianav replaced, I would get back to them.
Audible tones (beeping) heard while the Bluetooth is in use could be caused by the following:
The battery is low.
The active call was dropped.
A volume button has been pressed.
The headset is in the process of pairing with another Bluetooth device.
The active connection between the headset and paired device has been lost or restored.
